OD: From memory, I think all you have to do is disconnect the electricals, remove the endlink bolts on each hub and then remove the rack from the subframe... mostly 17mm bolts I believe. Wire up the rack so it's not hanging by the lines. Should have to crack the lines and make a mess. OR buy the replacement bar and S-can the rack. get an alignment, done.
Later
